Old 20-09-2012, 11:00 PM
Simons Simons is offline
Default Re: AUDI specific wiring diagrams...
Ok, thanks Richard, tomorrow I will test it
Old 21-09-2012, 11:24 PM
Runs perfect on the test!!
Old 23-09-2012, 03:49 PM
Thank you for the feedback
Old 21-04-2014, 08:37 PM
ysfg35 ysfg35 is offline
is it possible to wire the aquamist HFS3 to audi RS6 2009 ???
Old 22-04-2014, 08:51 AM
I will check, I am sure it can.
Old 22-04-2014, 11:32 AM
I will be thankfully if you make sure
Special thanks sir
Old 11-01-2015, 03:38 PM
Martin RS8 Martin RS8 is offline
Do you have a wiring diagram for Audi RS6 V8 biturbo BCY 2003-2005 ?
Audi S8 with RS6 engine = RS8
Old 29-06-2015, 11:10 PM
CactusS4 CactusS4 is offline
Default Re: AUDI specific wiring diagrams... 2.7T
W0w been a while, but I'm going back over my wiring and wanting some clarification.
Diagrams for the 2.7T Audi's have a white and orange wire to the N75, but in actuality it's white and brown from the HFS-3.
Also the diagram shows the Blue wire to the MPS/MAP Sensor, but the documentation shows us using the orange wire. "http://www.aquamist.co.uk/HFS3/manual/HFS3-v3.0w.pdf" Page 18
So there is some confusion (again since it's been a while since I hooked all this up and just trying to validate everything since I'm getting a n75 short to ground for some reason.
I think as of right now there is a yellow, orange, black wire out of the ECU RJ45 connector that are not being used.
I'm very hopeful that Richard is still up and kicking!!
Tory
Old 29-06-2015, 11:21 PM
The N75 wire should be brown and white, not orange.
Old 29-06-2015, 11:47 PM
So happy to see you around Richard. Thanks.. Can you also answer me where this miracle brown wire is? I have it wired but I don't see it in the RJ45 Jack, it's in the loom for sure and wired to my N75 but looking at the RJ45 I don't see the brown wire, is it somewhere wired together with something else inside the loom?
And then regarding the use of blue wire inside the diagram but the aquamist docs show the orange? (this darn Orange wire,nothing but trouble )
Tory
