Go Back   waterinjection.info > Aquamist specific system Q and A and new products > Aquamist systems in details and latest offerings
Old 10-12-2010, 02:18 PM
MaD^94Rx7 MaD^94Rx7 is offline
Default Re: Rotary "Summer" Unit GB interest
Hi Richard
I am very interested in this. Can you please explain the difference between the 2 kits? What are the effects on the pump running 100% methanol? How much does the pump cost?
If i buy directly from you what would the cost of the HFS6 / HFS3 + summer be in ?
Pls reply on my email henri_chetcuti at onvol.net
thanks for your help & time
Henri
Old 10-12-2010, 11:18 PM
System cost: see here:
HFS-3: ............ ?480 + NO VAT (until mid January). ?576.00(from mid January)
HFS-6: ............ ?580 + NO VAT (until mid January). ?696.00(from mid January)
Water pump comparisons:
HFS-3 ............. constant 160psi by-pass water pump (100% methanol compatible - 12 months+) $199
HFS-6 ............. constant 160psi by-pass water pump + accumulator (100% methanol compatible - 12 months+) $199 + $50
Fast acting valve:
HFS-3 ............. Fast acting valve + turbine based flow sensor
HFS-6 ............. Fast acting valve + turbine based flow sensor
Dash gauge:
Same
User adjustable on-board trimmers:
User adjustable triggering point:
HFS-3 ............. 12%-72%
HFS-6 ............. 12%-72%
User of adjustable triggering point offset:
HFS-3: ........... % trigger point % = % methanol injection point
HFS-6: ........... % trigger point % = +/- 20% methanol injection point
User adjustable IDC% gain:
HFS-3: ........... -50% to 150%
HFS-6: ........... -50% to 150%
Manifold pressure compensation:
HFS-3: ........... none
HFS-6: ........... 0-20% gain
Failsafe trigger delay:
HFS-3: ........... 0.2 to 0.6 seconds
HFS-6: ........... 0.2 to 0.6 seconds
Failsafe trigger reset timer:
HFS-3: ........... 3 seconds (fixed)
HFS-6: ........... adjustable 1-6 seconds
Old 21-12-2010, 08:46 PM
riprx7 riprx7 is offline
HI..
I AM intrested in summer + HFS-6
When is this out for sale?
Old 21-12-2010, 09:14 PM
Smile Re: Rotary "Summer" Unit GB interest
I'm in too.
1. Drunkengimp (summer+HFS3)
2. remydrm (summer+HFS3)
3. Snyrx7 (?)
4. trainwreck517 (summer alone)[/quote]
5. MaD^94Rx7 (summer+HFS6)
Old 22-12-2010, 07:36 PM
r2omega r2omega is offline
I am interested. Will you honor the current prices on the HFS6 and HFS3 kits when the group buy actually happens?
3. Snyrx7 (?)
6. r2omega (summer +HFS6)
Allowed: Turning then Burning. Not Allowed: Burning then Turning
Old 22-12-2010, 09:39 PM
FD-KAI FD-KAI is offline
There are two kits on offer, HFS-3 and HFS-6. Bith will woth with the summer. If like me to explain the differences between the two on the RX7 application, I am happy to do so.
if you be kind enough to do so... i'd be keen on summer + either HFS3/6 based on what is ideal for me.
Old 22-12-2010, 09:52 PM
I think you can read through post no.12 a bit further up this page and have all the info you need. If thats not enough Richard will chime in...
Guys pass the word around about this Group Buy as its our only chance to get Aquamist to produce a new batch of summers for our 13B engines
Old 23-12-2010, 03:34 AM
3. Snyrx7 (?)
7. FD-KAI (summer + HFS6)
Old 25-12-2010, 05:55 AM
RX72NR RX72NR is offline
Add me in for the HFS-6 and the summer
Old 25-12-2010, 10:20 AM
3. Snyrx7 (?)
8. RX72NR (summer + HFS6)
