Old 13-07-2011, 05:42 PM
Default Re: Faulty FAV valve?
Two settings
1. WL (gauge) ....... fully counter-clockwise
2. FS-DL (trimmer on controller) ....... fully clcokwise
3. Threshold trimmer at 11-12' o'clock
Let me know how it goes on this setting. I assume you have calibrated the gauge to read 5-6 bar at maximum load (SC).
Old 14-07-2011, 12:42 AM
[clone] [clone] is offline
I'll try this setting tonite. Yep the SC has been set. I'll let you know. Many thanks.
Old 17-07-2011, 11:02 AM
Ok have got the system sorted. After a fair bit of playing around and getting it just the way I want it, its finally all up and running
Big thanks to you Richard your after sales service is second to none.
One final question though, whats the best way of draining the howerton twin tank set up? I have just been running 100% demineralised water till I had everything sorted. Would the best way to just run the SYS and purge the tank till its empty? Or is there another method. I can not unbolt the tank due to the wiring.
The car is off to the tuners hopefully this week, will report back on results.
Thanks again
Old 18-07-2011, 02:10 AM
Howerton Engineering
Using the SYS jumper will spray through the jets. If you disconnect the 6mm line from the FAV, remove the INJ jumper and then use the SYS jumper, the pump will come on and empty out of the 6mm line.
Old 18-07-2011, 08:54 AM
Arrr, thought that was the case. Thanks Jeff.
