Old 24-11-2011, 10:21 PM
Default nozzle per cylinder setup
What's the best way to achieve this ?
Looking to do a nozzle per cylinder and controlled by the ecu. I assume Aquamists solenoid valve will work and flow enough for all 4 nozzles, or would more than one solenoid be required ?
Hoping for 4-500bhp on a relatively small 4 cylinder engine. Will be using water/meth, but want 4 nozzles to ensure each cylinder gets equal flow.
Just energise the pump at a preset MAP setting, and then inject liquid as required ? Probably just map water/meth flow relative to IDC for starters.
Sound sensible ?
Any other nozzle or solenoid options ?
