#11
Sorry Richard, I was totally off. 3/16"
http://www.grandprixforums.net/pheno...cer-12517.html I thought i had read that they were IC thickness. 3/16" isn't gonna get an injector in. What problems will a non sealed S/C cause for longevity. I don't think he will have a problem getting another one, and it might just give reason to upgrade to the Gen5 blower. Last edited by Dust; 13-02-2013 at 03:01 AM. |
#12
I don't think there is any possibility on sandwiching in the jet.
What about the supercharger body?
#13
This is the best pic I can find of the actual assembly
Hole at the top is the PCV valve. I guess the simplest place would be below that here is the Lower Intake manifold ![]() Bottom of the SC
#14
looks like post throttle is the only simple option. Unless you can tap into the side wall of the SC near the opening.
#15
What kind of increase in percentage should be considered on flow if having to go through the SC too?
#16
I really don't know the answer. You need to plot the S/C case temperature drop against the water flow under different load and ambient. It has to be done case by case basis. Do you have a few minutes to spare?
#17
I do, but he is in the US and I am still in Japan, wha tare you thinking?
#18
Data logging the drop in IAT (post SC)... Wmi flow rate against fuel flow. (rather boost, IAT(pre SC), RPM, etc).
#19
L67 doesn't have a post SC temp sensor as far as I know. It's before the MAF in the intake tube.
#20
You can purchase a thermocouple + amp quite reasonable price now. output is normally 0-5V.
