Old 26-02-2014, 05:37 PM
Default Re: FIDC too low for HFS-3 V3
I think you'd better send the board to Jeff to be repaired. I don't think you will charge you. Just pay the return postage.
He can even test it out at 40% IDC,
Old 26-02-2014, 05:44 PM
Chriswolf81 Chriswolf81 is offline
OK. Thanks Richard. I will send it to him. On another note: I used a 5k resistor on the orange wire on the ecu cable. Tephra said to use 5k in his thread, but you had written 220 in your diagram. Do I need to change this? Thanks
Old 26-02-2014, 06:17 PM
The tephra patch is very flexible. The software can make trimmings to suit any resistor. Send me the link and I will read it and change to 5K if needed.
Old 26-02-2014, 06:35 PM
http://forums.evolutionm.net/ecuflas...mod-v1-13.html
Its in post #188
Old 26-02-2014, 06:39 PM
Thank you, I will update it
The 220 ohm was decided some years ago so it is due for an update
Old 07-03-2014, 01:05 PM
any updates?
Old 13-03-2014, 08:43 PM
Just received the controller back from Jeff.
Thank you both for troubleshooting the mess I made.
What steps do you recommend from here?
What settings? Or measure the injector signal again?
Old 14-03-2014, 11:57 PM
I think you should go through the page 14.3 to 14.5 test procedures.
Please let me know.
Old 15-03-2014, 01:04 AM
Ok, I have to see when I get time to take the bumper off again.
One question:
If my cruise and wot voltage were 2 and 1.9 volts before, would they not both be right at 3.0 volts now. How does the controller tell the difference?
Old 15-03-2014, 12:49 PM
I don't think you need to get the bumper off. If you have the engine running, it will probably be OK to spray into the inlet tract for a second or two.
