Old 28-05-2015, 09:18 PM
parmas parmas is offline
Default Re: Adding jets to reduce IAT temperature?
Originally Posted by boukman View Post
Piping picture:
If it was my setup I would put a jet on the first output elbow at the angle, facing the nozzle on a straight line. I would also put one just where the first nozzle is located now and put the IAT sensor into plenum. Check readings and adjust nozzle size accordingly
Old 29-05-2015, 01:15 AM
You really need to move the pre throttle jets to the exit of the intercooler. This allows more time for evaporation and reduce charge temperature before arriving the Throttle.
Richard, Would you not get too much wall wetting by having the nozzles so far away leading to small delays before getting the full mist?
Old 29-05-2015, 08:45 PM
You can look at it another way, wet wall is lined with water. The first re-opening of the throttle, those water is going to be dragged towards the cylinders.
During this transitional period, it is going to cool the charge pipe. Don't forget there are still plenty of air moving to keep the engine running with the throttle shut.
Old 29-05-2015, 09:16 PM
Richard has a point. I experience a wet throttle body due to the post turbo nozzle after a high load run and then idle. The air temps keep going down although not injecting for several minutes and I have NO intercooler!
