Old 28-06-2015, 07:33 PM
mdhollis mdhollis is offline
Default Re: BMW N55 electronic wastegate
I have posi taps Richard that's a good idea. I'll get the voltage by the end of today
Old 28-06-2015, 10:41 PM
Engine running connector plugged in:
1. Motor (+) - 0vdc
2. Power supply(+) - 4.98vdc
3. Power supply ground
4. Wastegate rod position - 1.2vdc
5. Motor (-) - 0vdc
Old 28-06-2015, 10:59 PM
Thanks for the quick update. This is good, all makes sense. It appears the rod is at 1.2V at idle.
I think the next steps are leaving the sensor unplugged, go for a drive...
1. Slowly squeezing the throttle, if there are no boost, you can continue to squeeze the throttle slowly until wot.
2. Again squeezing the throttle slowly, if it starts to build boost. abandon the test.
This test is to confirm at what rod position in relation to boost or no boost. Once we have established this, we can then manipulate the pin #4 signal and control boost.
Do you think this is a good plan?
Old 28-06-2015, 11:10 PM
Yup I'll report back with results
Old 28-06-2015, 11:17 PM
We are getting quite close to take control of this.
Old 29-06-2015, 02:55 AM
Awesome!
Ok there is no boost. I make like 3 to 4 pounds at wot.
Old 29-06-2015, 07:52 AM
This very good news.
Just to recap ....
1. The rod is at "low" boost position at idle after start up.
2. After unplugging, the position of the rod is not changed.
3. Upon driving under load, the boost remained low.
Old 29-06-2015, 03:45 PM
Just to recap ....
Yup seems to be the case....
Old 29-06-2015, 06:42 PM
I can think of two ways to controlling the rod length.
1. Positive biasing the rod position voltage at pin #4. to the control loop should extend the rod and lower boost.
2. Positive biasing the T-MAP sensor.
3. Combination of the above.
I will set out a method to make this happen. I notice BMS sell a male/female plug for this wastegate sensor. If you can purchase one of those, I will pay you back. This will make life a lot easier.
http://www.burgertuning.com/N55_JB4_upgrades.html
Old 29-06-2015, 06:53 PM
Ok cool I have that harness already. I was actually going to mention it but I forgot. This harness only loops the wastegate rod position through the jb4....
Quick question, can this be done with a hfs-4 v2 controller? That's the controller I have...
