Old 21-03-2016, 07:00 AM
Default Re: Questions on my direct port meth setup
The red marks are good.
Old 22-03-2016, 10:22 AM
parmas parmas is offline
Originally Posted by robos4 View Post
Hey Parmas,
Sorry I meant I had problems without meth on the stock engine (when I rebui8lt it), cyl 4 was damaged due to running too lean. It must be a poor design from the intake manifold as it's obviously not getting equal flow. (the injectors were flow tested and came back fine).
Putting a jet just before throttle body in my mind wouldn't help me cure my cylinders receiving un even flow still.
Rob
You are using stock intake right?
Are you saying that Mitsubishi designed a poor design?
If that is the case I would consider making a custom one that will provide equal flow to all the cylinders and use one pre throttle body.
Water/meth could help but the setup is not right.
Old 23-03-2016, 01:02 AM
robos4 robos4 is offline
Thanks Parmas,
Sorry, so you are saying my meth setup is not right?
I would imagine most people chasing bigger power goals would go with nozzles in the IC pipe pre throttle body (and possibly in the manifold too) but I'm primarily going to use it for knock control.
Well, it's a fun project and it should all be complete and tuned by next week.
- Stock it gets 215whp
- Stock engine and bolt on's with HKS 7460 turbo got me 348whp (1.75bar)
- HKS stroker, MX1 cams, oversized valves, PNP, CBRD 7163 turbo kit, got me 424whp but I didn't set the IWG properly and wasn't holding boost..
- Now adding external fuel pump, larger intake, meth kit and firmer wastegate tune next week and shooting for 450-460whp.
Rob
Old 23-03-2016, 10:24 AM
I meant not tight to use a known unbalanced intake manifold and use water injection to "balance" the mixture
Old 24-03-2016, 04:32 PM
Guys,
Need to know the best angle to install the nozzles?
I'm having bungs welded on the intake ports which means I can now drill the holes at an angle (rather than straight down into the pipe).
Seems to be two schools of thought from who I am talking to:
- 45deg facing with the flow (nozzles pointing towards the cylinders)
or
- 45deg facing into the flow (away from the cylinders) as to ensure it mixes better before hitting the combustion chamber.
Or I guess I could still just go straight 90deg down into the pipes.
What's the answer??
Rob
Old 24-03-2016, 05:02 PM
I would position the nozzles similar to the fuel injector position made by factory.
If cannot be done as above I would make them at the bottom bend of the intake manifold
Old 26-03-2016, 12:39 AM
Thanks Parmas,
Richard/Rotrex - what do you think also?
90% of the pics out there of direct port setups have straight down 90deg and the other 10% have it setup like the fuel injectors facing towards the cyclinders.
Also, machine shop came back and places the holes about 1" lower from the original pic I showed you but doing it again with bungs welded.
Old 27-03-2016, 04:43 AM
anyone?
I am drilling the manifold tomorrow.
Old 27-03-2016, 07:24 AM
anyone?
Do you think there is a better person than a Mitsubishi engineer designer here?
I think the best option is just in front your eyes.... no need for any suggestions.
Notice the fuel injectors position/angle and make it similar if not the same whenever possible.
Good luck .... and post results and pics in return
Old 27-03-2016, 07:58 AM
Cheers,
No offense - always good to hear other opinions and it's the Internet after all did not know you were so educated in all this (my bad).
Just told workshop to follow your recommendations.
Hoping to have it all done by Fri and hopefully start tuning.
I was thinking of setting the spray to start about 30 to max 50% of what could be sprayed (not looking for huge power).
If you disagree, let me know.
Rob
Ps. Will absolutely share results and findings.. Who knows, part of me thinks it won't work (cause less power, can't find the right mix of spray v timing and fuel, meth sucking the lines causing rich spot after lift off, too larger jets etc)
