Old 10-12-2016, 12:03 AM
Default Re: Gauge Issue
I would check the wiring of the little red wire of the grey harness. I do not believe it has anything to do with the gauge.
Old 10-12-2016, 10:42 AM
Jor-El Jor-El is offline
Ok. I'll look. Which harness exactly?
Old 10-12-2016, 04:30 PM
read my last post again
Old 10-12-2016, 11:48 PM
Ah ok The Grey one is the Ecu harness. Correct?
If that's the correct one, I couldn't tell if there was an issue with the red wire.
I'll take another photo where there is light and post it.
Old 11-12-2016, 08:04 AM
I was referring to the other end of the grey harness where it splices into the ECU.
Old 11-12-2016, 11:28 AM
Ah got you. Will check
Old 11-12-2016, 07:47 PM
Connection of the red wire looks ok from what I saw
Old 11-12-2016, 09:31 PM
In this case, I don't know what caused it. You may need ot return the controller back to me for checking.
One more thing, check the plug end of the cable is in good condition, you should hear a positive click when engaged.
It i snot easy to diagnose an intermittent problem.
Old 11-12-2016, 09:40 PM
Can you tell me what car is it?
Old 12-12-2016, 10:50 AM
Hey Richard. The plug on the grey harness clicks when installed. It looks to be fine in terms of condition.
I think I'll check the entire length of the same red wire to make sure none of it is damaged
The car is an evolution x
