What jet jet size are you running?
HP 240
Fuel injector Bosch 0280 155 868 with 380ccm where can i find the instructions for the AUX function? Last edited by Gunther; 30-05-2018 at 08:02 AM. |
Jetsize 0,4
one 0.4mm jet is outside the control range of the aquamist system. Your engine should be able to receive more flow.
Sorry, 4 x 0,4
Do you think you are injecting too much water?
i dont know. It may be that the controler runs in Failsafe but only so short that it is not displayed on the instrument and the MAP is not switched and that so fast behind each other that the engine does not get enough water
