Old 02-10-2014, 06:52 PM
vsgts14 vsgts14 is offline
Default Re: hfs6 problems
ok rich, is that the only thing i have to do, and then the system will work properly?
Old 02-10-2014, 08:58 PM
hey rich, i connected those two wires and i'm not getting any spray using the test jumper. am i missing something?
Old 04-10-2014, 12:24 PM
send as picture of your connection work.
Old 04-10-2014, 02:40 PM
will do. basically, i crimped that brown wire to a new wire and soldered it onto the coil (the wire on it, was not long enough).
i tested all the voltages and it's getting voltage.
i also manually jumped a ground wire to the coil just to make sure the valve was not dead and it indeed does spray out.
Old 04-10-2014, 06:46 PM
If you use the TST to activate the system. The other jumper link must be on IDC.
Old 04-10-2014, 09:15 PM
i had them on MPS/IDC/TEST.
the car was tuned yesterday, with all the jumpers etc set as if it would be tuneable, but nothing happened. there's a fault somewhere.
should all the RJ connections have a green light lit?
Old 08-10-2014, 05:31 PM
Time for a new system?
Old 08-10-2014, 05:39 PM
at this point, it points that way correct? is there any way i can buy parts and convert this one to say an HFS3? i mean, the pump wiring is the same, the gauge is the same, the power supply is the same. i would need the control box and injection box.
Old 16-10-2014, 07:49 AM
None of the connectors are the same. It will be a mess if you to it this way. You can get the H3 system from me minus the pump. Email me.
