Old 16-04-2017, 07:18 AM
Default Re: Map sensor or lack of?
test points:
TP #5 ........... Steady 12V, system start signal.
TP #11 ......... 9V internal reference
TP #15 ........... 5V internal reference
TP #16 .......... IDC signal. voltage should increase with stabbing of pedal.
TP #20 .......... Trigger setting
Old 16-04-2017, 10:57 PM
VeightTT VeightTT is offline
TP 5 - 14.15
TP 11 - 8.94
TP 15 - 4.95
TP 16 - 0.05 - 0.32 (throttle blip)
TP 20 - 0.59
Old 17-04-2017, 07:39 AM
The results are good except for the IDC signal, It is a bit weak.
Got the nice pics from you yesterday, all looks good,
Next test:
Link FDC (hi-jack gauge to display F-IDC) and let me know how many bars is displayed on the gauge at WOT.
Old 17-04-2017, 09:47 AM
I have found a pin out error on the previous drawing (v1), here is the corrected version (v2): Many apologises
Old 18-04-2017, 02:49 PM
Hi Richard
I had my car at the installers today had it re-wired and tested all was good at the engine side but there is still no boost signal everything else is working as before. I have tried all different settings trip - mps, trip, p/I-r, threshold turned all the way down gain at max etc, etc. idle voltage 0.40
Cheers
Andrew
Old 19-04-2017, 08:42 PM
Did you see the new drawing above, the map sensor is on the right side of the ECU.
I like you to take a picture of the MAP sensor wiring on the ECU. I want to see this rather based on your words.
Old 09-06-2017, 05:33 PM
Hi Richard
I finally managed to pull the ECU and get some pictures for you all the wiring and connections are good I am getting good voltage at the tie in to the map sensor all the way to the connection to the grey harness plug but its not making it to the board. I don't seems to be able to upload photos so I will e-mail them to you
File Type: jpg IMG_0002.jpg (157 Bytes, 15 views)
File Type: jpg IMG_0003.jpg (157 Bytes, 15 views)
Old 10-06-2017, 08:12 AM
email to richard at aquamist.co.uk
Old 10-06-2017, 08:15 AM
I e-mailed the photos to you after I posted the last msg
Old 10-06-2017, 08:19 AM
found them.Are you Andrew?
