Old 18-11-2014, 10:59 AM
Talking Re: RICESP Water Injected RX7
New inlet manifold set up arrived today
Modified refined rotors are ready
Engine block modifications done
The specifications of the new power plant are 'exceptional', very high specific power per bar of boost, and ability to make the turbos limit on the most 'basic petrol' no need for even premium fuel!.............. so stuff that you can buy ANYWHERE in the world
Again all with the power of water injection
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 18-11-2014, 12:48 PM
Grant M Grant M is offline
What inlet setup are you using?
Old 18-11-2014, 02:39 PM
13B-RE Cosmo
Old 18-11-2014, 02:46 PM
So you are using Cosmo plates too? Biggest of the standard ports;-)
Old 19-11-2014, 12:20 AM
No REW, they are simply ported out so they are the same as the Cosmo at the end of the day, just need a little rework.
The beauty of the Cosmo intake is the primary runners mostly as they are the right diameter to work with the RICE RACING street ports timing, the other big thing is the shorter manifold length as well as the plenum, all up a much better inlet manifold to use on my set up.
I have a real good document I made showing power per 1 bar pressure, I have a basic version listed on RCC forum, but my updated one is very extensive and proven, this set up is proven to deliver between ~250bhp and ~320bhp depending on ancillary items and other hardware specifications, such as CR, porting, turbocharger, exhaust etc etc.
Anyway, it will make 'high' power but have the ultimate in transient response and delivery + be usable anywhere anytime #1 design parameter.
Old 19-11-2014, 10:17 AM
What sort of response are you looking to achieve? Around 3500 and a rev limit of 9000? That will would be a really nice FD to drive with that power curve on boost.
Have you thought of using the 4 branch manifolds available or will they not give you better low end??
Old 19-11-2014, 10:53 AM
What advantage does the plenum give you? Over the FD UIM? A larger volume of air available to be pushed into the engine?
Old 19-11-2014, 01:04 PM
Main advantage is increased air flow to allow the ports to work, I have some special RICE RACING spec rotors which give earlier port open timing and alter closing, again all designed to work with the inlet manifold.
The turbocharger I have is referred too as 'H' version of the EFR9180, it's got a 1.45AR rear housing on it, I run a V60 Tial waste gate on it.
The full rotating assembly is balanced, clearanced, and lightened to work to 9500rpm reliably and at high output. The engine will have a working range from 4000rpm to 9500rpm, however the parts summed together will have a 'sweet spot' from 5000rpm to 9000rpm @ 2 bar gauge pressure or around 3 bar absolute pressure.
Set up looking for real honest power of about 750bhp to 800bhp @ the engine, that is very quick in transient response above 4000rpm, below that the engine porting was not designed for really, that was/is more the realm of stock standard Mazda Porting.
To put it into perspective for you (common 9.0:1 CR 13B-REW ancillaries small to medium size single turbo)
Mazda Porting = ~190bhp per bar of pressure
RICE RACING street porting = ~250bhp per bar of pressure
This set up with 7.5:1 CR RR spec rotors and increased timing and Cosmo inlet manifold (note you loose some power per bar of boost due to lower CR! as is normal but you far out gain that loss in increased boost pressure and tollerance to knock) will yield around 260bhp to 270bhp (OR MORE!) per bar of pressure on a 'state of the art' appropriate sized turbocharger
This is due to some trick timing changes allowed by the rotor face contours, all without needing to go to an inferior bridge port inlet
It does get complicated but without giving too much away (all my competitors like reading my posts LOL) its the interaction of all of these parts that makes for an efficient set up, but not only that, what I have engineered is a reliable and durable set up, one that can be used in the real world any where any time and to its full capacity without excuse ............ which is what a real street car is all about.
Lots of things have been in development thus why I have been not on here much, don't fret though all these will be showcased in RICESP and other places that I can let you know about one day but people like to keep their advantage a bit of a secret for a while LOL......
Old 21-11-2014, 11:00 AM
Just reading it I what you are putting together is going to be an amazing setup.
Am I understanding you right that you have altered the inlet timing with the rotor face? Does that mean you have scalloped the rotors? Does doing this give you such a lower CR?
I think people only really go for bridge ports these days because of the "Brap" it is the rotary trade mark sound with the advances in ECUs and development of things like WI etc people are making there power with boost, and you know more than most the benefits of boost
Are you using your existing WI product or have you developed an even better system? After all we are on the water injection forum so thought if ask
Old 21-11-2014, 01:33 PM
Yes I have the rotor combustion pockets machined as well as a very advanced scallop done but unlike any other
The engine well I think the set up will be o.k. just keeping it realistic and achievable, something I can use.
For the water injection it is my old faithful RRWEP140
