Old 29-04-2012, 09:49 PM
fplucid fplucid is offline
Default FCM Problem ::FIXED::
Greetings from Russia.
Trying to install HFS-6 on turbo s2000. After finishing all the wiring and trying to start, I've noticed that there is no connection to red cable coming from FCM (under hood). Neither green or yellow lights are lit. Other connections are fine, only this red one has problem.
One thing I've noticed plugging red cable out and in - "S" light on gauge is lit only with cable inserted, also just in a moment of inserting module is making a "click" sound (similar to sound made by relay). Ground to FCM is good.
I suppose that something is working, something is not. When I tryed to run 100% inj test all indication on main board was correct, but flow didn't run, no sound from pump as well (pump fuse and relay are ok). Could be this the reason of FCM not working properly?
Basically, what is possible reason for this and how problem can be resolved? Any suggestions?
Looking through topics here I found out that red RJ connector sometimes has some problems - I will check it out tomorrow.
Thanks for your time and sorry for my english.
