Old 15-06-2015, 11:30 PM
Default Re: Failsafe with HKS EVC 6
Gauge button on always.
Read the following, ignition off:
TP4, TP5, TP7, TP8, TP10, TP11, TP15, TP16, TP17, TP18, TP20, TP23, TP30
Read the following, ignition on, pre-crank:
TP4, TP5, TP7, TP8, TP10, TP11, TP15, TP16, TP17, TP18, TP20, TP23, TP30 (same as above)
Read the following, engine running:
Old 15-06-2015, 11:33 PM
Originally Posted by P997.tt View Post
Here is the picture
Th One more picture of the whole board. The left side is missing.
Old 15-06-2015, 11:34 PM
P997.tt P997.tt is offline
Ok Richard thanks for your support, will test them in the next couple days and update this thread ...
Old 15-06-2015, 11:51 PM
OK. I look forward to the readings.
Can you take a hi-res, close up picture of the plugs of both gauge cable. Long and short. Make sure they are in focus.
Old 16-06-2015, 05:49 AM
Hi Richard, results are in, let me know what you think
Old 16-06-2015, 05:50 AM
Original cable end
Old 16-06-2015, 05:51 AM
Extended, other end is a mirror just like the original, both behave the same ..
Old 16-06-2015, 08:17 AM
One thing stood out on the tests, the red wire of the molex is not correct, Check this wire. Should be A8 of the DME.
Old 16-06-2015, 10:50 AM
It is connected to A8, in fact it is twisted with the other red wire from the ECU harness and tapped into A8 at the same exact point
I will check and adjust that wire, which test point to check after and what should the reading be?
Old 16-06-2015, 11:28 AM
I went back to the car rechecked the red wire from the molex connector and it is definitly in contact with the A8 pin wire ... I even untwisted it from the other red wire from the ecu harness and gave each wire its dedicated contact space on A8's wires ......
Still, the water level light remains, but I noticed this:
When the A connector of the car's ecu is disconnected the water level light goes away, but the gauge background and S led is still working, as soon as I plug in the A connector /harness the light comes back on again ...
