Old 10-06-2017, 08:20 AM
VeightTT VeightTT is offline
Default Re: Map sensor or lack of?
yes Andrew
Old 10-06-2017, 08:22 AM
I saw the voltage of 0.771v at the ECU. it is quite low for the MAP sensor. It should be around 1.5v at pre-crank. Also check the continuity of the blue wire of the grey harness because the the same voltage was not appearing the the RJ connector.
Old 10-06-2017, 08:37 AM
yes the continuity has been checked the voltage is not making it from one end to the other. how else am I supposed to check it?
Old 10-06-2017, 08:56 AM
I suppose you can use the resistance option on the Fluke to probe the the two ends on the the blue wire. It should be near 0 ohms. One end on the gold figure of the RJ. May need to sharpen your probe.
