Old 16-12-2019, 12:46 PM
Originally Posted by Rub20B View Post
we run max 950 egt but run the engine mostly between 7 and 9k rpm.
https://www.youtube.com/watch?v=8CExNDVC1WI in this movie if you put quality to 1080p you can get an idea of the response time
So the issue with these is that they never get anywhere near the real temperature.
You will see when you fit a pair of mine that it will more than likely read 100+ deg C higher than this below, and not constantly creep up all the way down the straight
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 16-12-2019, 01:07 PM
Ruben, here is a 3mm closed probe v's an open one (for EGT application) super extended but they dont last in real world (3000km in road car).
Anyway you can see the 3mm closed version suffers from never reaching temp and delays, not to mention being very long way from reporting something near accurate end figure.
This is all legacy info from decade ago put over onto the LR software to see in a nicer format.
What I have made is a probe that exceeds the fine wire super extended tip, but in a fully enclosed Inconel 600 form and many factors higher response rate, and better accuracy.
Old 16-12-2019, 01:27 PM
Exclamation Re: RICESP Water Injected RX7
In the below video these are my previous suppliers own type of probes, open element but in a stupid 1/4" size, they respond ok & are tolerable for some kind of indication of temperature.
My own design is 5 times faster than these and read ~100deg C higher at peak temperature, so far more accurate. This is super important for TIT cause I know I have lost count how many times have pulled apart a turbo to see the blades in distress, when in reality the poor cunts have been seeing temps that are maybe 200 or 300 degrees higher than what is reported via sub standard understanding of how an EGT Thermocouple works, IE: as a friend of mine said rightly it reads the temp of the probe and not so much the thing its measuring !@
Video > https://www.youtube.com/watch?v=cl8i...ature=youtu.be
Old 17-12-2019, 01:36 PM
Wink Re: RICESP Water Injected RX7
Got a heap of them in stock as of today, but almost all sold !
Old 17-12-2019, 02:16 PM
Rub20B Rub20B is offline
How much shipped?
Old 17-12-2019, 02:39 PM
How much shipped?
For 2 x probes to Belgium with tracked ~8 business day delivery = ***sent***
Old 17-12-2019, 02:41 PM
For 2 x probes to Belgium with tracked ~8 business day delivery = $330Au
email sent
Old 20-12-2019, 12:19 AM
Talking Re: RICESP Water Injected RX7
Some more 'fact v fiction' here > http://www.syvecs.com/forum/viewtopi...5&p=6712#p6712 others talk about 'testing', when we get asked it gets done within minutes enjoy
Old 22-12-2019, 04:06 AM
I get asked for picture of the probe and details so as below:
* Inconel 600
* Motorsport 'high heat' tolerance potted strain relief (these wont break/fail at the junction where the wires are joined - unlike some)
* As per video's they are accurate as can be while being durable and also allowing multi function use (any vehicle air/fluid measure)
Old 23-12-2019, 04:15 AM
https://www.youtube.com/watch?v=_dnmzf1lD9A
^ latest video using a calibrate meter
More details here > http://www.syvecs.com/forum/viewtopi...5&p=6722#p6722
