#41
Which diagram did you follow and did you splice the injector signal pick up wire from the ECM or from the fuel injector?
I like to check your wiring.
#42
I followed the mazdaspeed3 wire diagram v3
#43
Can you send a link to the v3 diagram.
#44
Here's the diagram, the only thing I soldered different on controller was 3 map instead of 2 cause I'm running big turbo
#45
I am confused, which part of the diagram says v3?
#46
Ok so I upped my thresh and everything is working awesome, delayed the duty cycle, failsafe is tripping it's good I think
#47
Thanks for the update. Sorry I couldn't help much.
#48
Do you have an updated wiring diagram for the HFS4-V3.1 for a 2008 Mazdaspeed 3?
#49
Reason I ask is the HFS4-v3.1 manual calls for the red, green, and blue cables where the diagram on page 1 shows red, green, and yellow cables for the RJ48 connector.
#50
I think I found the answer to my own question. Looks like page 20 (in the manual) shows the correct wire layout for DI applications which uses the yellow cable.
I did have a few questions on the jumper and solder settings though. For the jumper settings, I believe all of the settings should be set to the default setting except the SET FAIL SAFE. I will be using an external trigger with a 5-12V input, so I believe this jumper should be set to FS1. Both CLP and FS0 jumpers can be removed. I will use the orange wire on the RJ48 connector and splice it with the external trigger of the boost control device. For the solder settings, I plan to use the following settings: AUX INPUT: default IDC PRE-SCALER: x2.5 for DI MAP SENSOR TYPE: 2.5 bar MAP sensor so I believe I need to solder link 2 FLOW SENSOR MAP: I'm using a single 0.9mm jet so I need to solder pads 1 & 2 AUX INPUT SELECT: default AUX INPUT FAILSAFE: I believe this should be W? Are these settings correct? Last edited by Puddin15; 18-08-2016 at 05:00 AM. |
