Old 13-12-2005, 09:06 PM
K3FUS K3FUS is offline
Originally Posted by ashtal
Has there been anyone with a sucessful 1s kit on an astra turbo or any z20let ? I who of a fair few people who have WI on there car but no reals gains ! Richard from a turbo car running around 250 - 270bhp Should you see much improvement in bhp / torque with an 1s kit ?
:sad:
Old 13-12-2005, 09:10 PM
I wouldn't expect a great deal of gain in winter without tuning. Water's main work is cooling and if there are little cooling to be do , it will have to induce soem heat ( Boost, leaning fuel etc) to get the benifits - In summer, it will be a different story.
:sad:
Old 13-12-2005, 09:40 PM
Friday is good for me, not sure what time yet though. I'll let you know.
Old 13-12-2005, 09:42 PM
Great, just post the time here.
Old 14-12-2005, 12:21 AM
neil neil is offline
i can report that wi does help in piston cooling as i have proven this down at courtenays on there rollers(ask jon) i have a jet in the throttle body and i am using a 75/25 meth/wat mix,we did a run without wi on and the ecu cut the timing due to the heat soak but with wi on the ecu did not cut the timing at all so it does help keep temp down so in a way it is a gain in safety and peace of mind that ur engine is running more cooler so there is less chance of pinking at higher rpm. . i am running two s1 kits one for piston cooling and one for charged air cooling(switch off at mo as dont need it up here in a very cold aberdeen lol) i also have a custom made water tank for the charged air cooling only,
Old 14-12-2005, 10:35 AM
Neil, so your jet is after the induction temp sensor. It is interesting to know that you had a gain by doing it this way. This is what we plan to do on Friday, hopefully I will be able to feel a difference between before and after the inlet temp sensor.
Richard - how does 9:30am Friday sound to you?
Old 14-12-2005, 10:48 AM
9.30 am is fine, I will be there. How much time do you have?
Old 14-12-2005, 11:33 AM
As much as you need as I have the whole day off.
Old 14-12-2005, 11:40 AM
Wondeful - we can try a few others things as well.
Old 14-12-2005, 12:12 PM
Sounds interesting.
I look forward to it.
