Old 09-09-2022, 12:35 AM
Exclamation FAKE NEWS !!!
Be ware of FAKE NEWS !!!
So many years of reading now seeing this rubbish, we just feel it is necessary to debunk this... FACT V FICTION !
https://youtu.be/80AcdZ7WdgI
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 16-09-2022, 11:14 PM
Default Re: FAKE NEWS !
"Never seen water meth make power!"
So for the naysayers simpletons and morons out there on GagTube looking for knowledge here it is! 11 recorded drag runs all in 10s, more than 10 minutes of run time at full 'on-load' power, all proven with log book records and time slips.
NO FAKE NEWS !
Real road car
Real performance
Real durability
Old 11-12-2022, 05:04 AM
Exclamation Re: RICESP Water Injected RX7
Here is a link that will go live on the 17th December, owner talking about his car using RR WM technology and Syvecs ECU in his Mitsubishi EVOX SST road weapon !
https://www.spreaker.com/user/163209...-justinparis_1
^ Click on the above ^
Old 17-12-2022, 01:00 AM
https://youtu.be/lRjFvryqgmc
^ above video ^ showing some current technology around heat control on exhaust system related parts, and pictures and detailed description below.
Using our own *donmega* EGT probe we check the actual combustion gas temperature on a piece of lagged piping. To see the temperature reduction a couple of fine wire Type k probes are put in various locations some touching right on the outer cover and others less than 1mm away from the surface.......... To finally give it some real work context I held my hand (try not to shake and touch the surface!) about ~20mm away from the outer cover and can be there for unlimited time (very little heat radiated).
Some pics
Old 18-12-2022, 10:16 AM
Orlando (CRE) Orlando (CRE) is offline
Administrator
Nice work Peter. Great info. Going above and beyond always.
Old 18-02-2023, 01:21 AM
I have a raft of cars running Aquamist main hardware (pump, HSV, flow meter, nozzles etc) on our own Syvecs WMI control box. When time and relevant IP allows will post some up here otherwise as always you can reach around to me and can accommodate you NP.
Old 22-10-2023, 01:13 PM
https://www.syvecs.co.uk/forum/viewt...2daa4&start=90
^ For latest development updates take a look here for Squirting Technology
Many many more cars coming !
As always will continue to lead the way as we have for the last 30 years and for the next 30 Kuntz !
Old 23-10-2023, 12:21 AM
http://www.riceracing.com.au/rides/M...SST_Justin.htm
Old 25-10-2023, 12:42 AM
More Squirting Action sneak peak here below
