Old 26-07-2012, 03:13 PM
Default Re: FCM Problem
If the FCM box is not closed, the hall effect sensor on the circuit board will not read the turbine of the flow sensor
Close the box and repeat test 4 and 5.
Old 26-07-2012, 04:40 PM
fplucid fplucid is offline
Yes, this really helped. Thanks again, Richard.
Nozzle was full of dirt - probably it got there during these several month of laying under hood unconnected.
Currently everything is fine and flow sensor shows 7 bars in "TST" mode.
You said that box should be completely closed - should I re-seal it to be 100% sure that is sealed completely?
Old 26-07-2012, 04:46 PM
The circuit board is epoxy dipped to protect it from the environment. But the modification you did with the black and brown wire may need further moisture protection. May be tap up the gap of the FCM will do just as well.
Old 26-07-2012, 04:49 PM
The next step will be taking the car for a drive and play with the trimmers.
Old 02-08-2012, 04:26 PM
Thanks, Richard. Everything works just great.
I would like to build up direct port system. I think this will make sense. Which parts will be required? Can I ask to to assist and make a quote?
Old 02-08-2012, 05:07 PM
How many cylinders?
Old 03-08-2012, 11:51 AM
standard R4
