#71
R35 GTR tested yesterday at EC circuit. ~242kmh on straight max speed.
Boost up, exhaust, tune, smaller wheels, minus passenger seat and a bit of weight etc (1750kg run weight) 90km/h-140km/h time's 2.83 seconds to 3.04 seconds, not allowed to tell you lap time. But does show ~325awkw on VBOX on track and runs 125+mph at EC Drags too. ^ Some may find this a bit interesting given all of the hype around the R35GTR, shows a little old Mazda Rotary can hold its own I think. My VBOX module turned up today, I will run the current specification on 17.5psi boost pressure and put up the 90-140 analysis for you to look over.
#72
Re: RICESP Water Injected RX7
Getting better and better by the day.
#73
Yes I am very happy with it, especially the power band of the engine mostly. These days too much emphasis is put on "hollywood" power outputs with no consideration given to the rest of the power story.
Massive rain storms here so no testing this week, but will recommence soon.
#74
Well I tested it today with the VBOX3i hooked up.
My on board Blitz boost/power meter showed 278rwkw @ 6600rpm and the VBOX3i with my own formula gave 273rwkw @ 6650rpm I have done up an Excel sheet summarizing the 90-140 time V's the R35 GTR <resized> <original> http://img12.imageshack.us/img12/7232/vbox90140test.jpg In summary the power went up from 235rwkw to around 273rwkw @ peak (16.8psi v's 14.5psi), on a linearized scale (for boost difference) you can see that the Water/Meth mixture account for another 20+rwkw as I measured it. I did test at a higher location (100meters higher than normal location) and the weather was about 7 deg more than the base run. I have trimmed the fuel a bit more after this run today (you can see it went rich) I have also put the WI system back to 2.5 turns), these adjustments should bring it back to my target of around 11.5:1 or so.
#75
O.k. Here are the testing graphs I promised. In summary they are the first ever setting ~230rwkw region on water. Then I changed to 50/50 and up rated the boost to 1.2kg/cm setting (can see actual logs figures across RPM ranges on various graphs) along with refinement of fuel mixture to point of last graph where its at the target range of 11.2:1 or there abouts.
The difference on road is excellent with power all the way to 8000rpm. In 2nd gear traction control needs to be turned on.... I have done a months worth of testing at this level and its very strong with no problems, system parts can tolerate the mixture too (tested 2 months now or more). The last graph today was a bit warmer in weather, but test location was exactly the same and it shows the extra power in last few hundred rpm due to just the mixture change alone. All tests car was exactly 1320kg as tested (complete with driver) I will eventually turn it up to 1.4 to 1.5kg/cm boost but am happy with the way it is now has more than enough power for track work and an good spread too. My experience with the meth mix in my own case yielded some more power for like conditions so I am glad I went down that path, improved 90-140 from 3.11 seconds to repeated 2.89~2.87 second range (probably faster as these tests were 100m higher and also in ~10deg C hotter test conditions). 1.00kg/cm boost setting WATER 1.20kg/cm boost setting Water/Methanol, to rich at high revs 1.20kg/cm boost setting Water/Methanol, better mixture across range Spread sheet of VBOX data showing average data for both 1.20kg/cm boost tests (repeated sub 2.9 sec 90-140 tests, note higher average power in last part of rev range for correct mixture setting) <resized> <original> http://img294.imageshack.us/img294/447/vbox120kg.jpg
http://www.riceracing.com.au RICESP > F40 > Zonda > ZR1 Water Injection Specialist "Can't be defeated!, don't know the word!, shoulder to shoulder!, we'll fight the world!, WE CAN'T BE BEATEN!!!" Last edited by RICE RACING; 13-03-2010 at 06:47 AM. Reason: more graphs |
#76
Forgot to add: (Avg-b) *for boost and power* between test lines are averages for those measures between test line obviously (separated in 10km/h) figures, and you can see the rpm at each 10kph test line. You can see the repeatability of performance for like figures and the obvious gain in average power for the last 10kph incremental (~6600rpm to ~7200rpm).
Peak power for both tests was 273rwkw and 271rwkw (first at 6600rpm and second 6800rpm, but holding near this peak level over a much broader range) and holding this to 7800rpm, rev limit is set to 8300rpm and changing point is ~8000rpm. Hope people find this of some use.
http://www.riceracing.com.au RICESP > F40 > Zonda > ZR1 Water Injection Specialist "Can't be defeated!, don't know the word!, shoulder to shoulder!, we'll fight the world!, WE CAN'T BE BEATEN!!!" Last edited by RICE RACING; 13-03-2010 at 09:08 AM. Reason: more detail |
#77
Fine tuning to the AFR curve and spark timing and WI delivery all helped heaps ....... its awesome, want to try 1.4bar now ! hahaha
#78
A lot of fun info for the weekend. Did get much time to enjoy those wonderful information yet. Thanks for posting.
#79
Any time Richard
I am real happy with it as she makes solid power to near 8000rpm, I did have to modify a few spots to do with my Fuel table where interpolation was not enough between arbitrary 500rpm points, so at 6100rpm and I thing 7350rpm I had to put it specific lines to mention just 2. All of these things add up to make a big difference in how the engine operates when trying to set it at this minimum AFR point while still giving plenty of fuel for cooling. As the motor was dropping into say high 10 AFR points it showed very obvious drop offs in power which you could feel in the drivers seat. Once I got onto all of these such mapping points and it was hitting the target 11.2 through the whole rev range it literally transformed the way the engine worked (I think as I posted earlier? or that may have been the diff of going to 50/50? either way similar reaction was noted). I feel now I have a good base to work from and the power for boost in street trim is right up there, the rest (more power) can either be from increased boost pressure or maybe overall trim to target AFR (might try 11.8:1 and then 12.5:1). There was a quantifiable difference in my own car to trimming up the AFR firstly on the water alone (from way back in early posts) then the W/M. There is obviously heaps to refining any one set up is the moral here I suppose. Only extensive testing and on road or dyno analysis will give you the answer maybe as to whats the best settings for any given car and its combination of parts.
#80
That last sentence is the hardest thing to get across to most folks. I've seen seemingly identical cars react differently from what would appear to be different sensor readings(inputs) and ECU builds.
Everyone always asks what they will get get out of a system, and I have to say the same as you, it really depends on how much you datalog and refine it. Each car and application is somewhat unique. Congrats on getting yours where it is. That sounds like a very fine setup. |
