Old 28-05-2010, 08:00 PM
abcmzy abcmzy is offline
Default hfs-6 install problem??
i installed hfs-6 system on my tt 350z,runing 800cc injectors,50/50 meth
two jets one 0.9mm one 1.0mm with 0.9mm restrictor on the unit.
when every i turn off the ignition the nozzles will spray for 1 sec is that normal??
all pre-test are ok
Old 29-05-2010, 02:33 PM
Default Re: hfs-6 install problem??
Can you check the red wire from the yellow connector is wire to a 12v source that only becomes active at the same time as the fuel injector(+)
If you have an ECU pinout for the car, I can produce a specific wiring drawing for this car.
Old 31-05-2010, 04:09 PM
Trouble in Italy, the installer put on BMW racing car HFS 6 and works out when the engine is off... please Richard which is the wrong wire connection???
