have qusetion please
am running my aquamist methanol injection and am very vary happy , great prodect , clean and you can feel the quality ..
anyway , i have a simple qustion : *the system settings are working fine with my setup , in the future am going to run race fuel c16 , and i should not run methanol injection , in the same time i do not want to lose methanol Advantage of cooling the iats , so i decide to run less amount of methanol to cool the iats .. as i know there are 2 way to run less methanol : - use restrictor - adjust the gain little down which one is better ??? any other idea ?? btw am useing 2 jets , and i can not run just one .. thanks |
Re: have qusetion please
Either one will work.
Gain will only affect the spray from threshold point onwards. Restrictior will reduce the entire curve. I think lower the gain will be better as having colder air lower down helps spool up. As RPM rises, the system will not spray as much.
thanks alot man .. i think restrictior will be better , cuz i do not want to adjust the settings again and again ..
I suggest putting in the 0.7mm restrictor.
you are right .. will do that and see ..
thanks richard |
