Old 19-03-2012, 03:06 PM
5mall5nail5 5mall5nail5 is offline
Default Direct port siphoning
Hi all,
Recently put in 0.5mm jets in 6 intake runners behind the throttle body. Works great but I can tell that my overrun isn't as clean as it was for a split second or so after I close the throttle. I can deal with it, but I know the vacuum is sucking some fluid from the lines. I came back after a pull and saw the lines were not full. Are there any small check valves that Aquamist recommends and is it even worth while? Just another thing to fail. I can deal with it, just looking to see what other people are doing.
Thanks,
Jon
Old 21-03-2012, 10:52 PM
St00ge St00ge is offline
Default Re: Direct port siphoning
Howerton engineering sells in-line check valves
Old 24-03-2012, 11:49 PM
Most kits with port injection use an inline solenoid to prevent liquid being sucked in under vacuum conditions.
Old 25-03-2012, 05:15 PM
Howerton Engineering
Originally Posted by 5mall5nail5 View Post
Hi all,
Thanks,
Jon
http://www.howertonengineering.net/p...-Hosetail.html
Old 08-10-2012, 03:59 PM
blue blue is offline
would this be a good solution for a m45 supercharged mini
i have my main jet positioned in outlet horn after intercooler in the "approved way"
but have a secondary smaller pre charger feed as well
i have recently had occasional cold start issues [not firing whilst turning over] and was wondering if i was siphoning out too much water [high water ratio as not tuned for meth]
at start up?
blue
Old 08-10-2012, 04:47 PM
This may be a solution for you:
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2323
Tags
direct port, siphon, siphoning
