Go Back   waterinjection.info > Aquamist specific system Q and A and new products > Aquamist systems in details and latest offerings
Old 14-07-2013, 03:43 PM
Howerton Engineering
Default Re: NEW product... checkvalve jets
If you have an issue due to gravity or PD then they would help, but otherwise probably not needed.
Old 15-07-2013, 02:41 PM
Ok, thank you!
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Old 08-06-2015, 10:17 PM
vlopatin vlopatin is offline
Hello, have to of check valve jets installed before throttle into intercooler pipe. Suddenly got "error" lights in my HFS4 controller and find out that one of two nozzle stopped spraying... So my questions - is there any options to make it working back (what should I check)
Thanks in advance
Old 09-06-2015, 08:25 AM
Thanks in advance
Did you recalibrate the WL and WH after putting in extra, that is the impression I got from your post.
Old 09-06-2015, 10:09 AM
Yes, I did. I had 2x0,5 standard type and several month ago changed them to 2x0,7 checkvalve - so it was ok till yesterday. It doesn't work even if I remove it from the pipe and run test (second one is ok)
Old 17-06-2015, 08:27 AM
If you have one nozzles suddenly stop working, Open it up and check for debris. This is the only cause. Make sure you do it on a clean table top. Make sure every o-rings are seated properly during reassembling.
