Old 22-03-2006, 06:47 PM
Default How many 0.3mm jets can a 1s kit run?
Err.... How many 0.3mm jets can a 1s kit run?
Thanks.
Old 11-04-2006, 09:40 AM
JohnA JohnA is offline
Definately 3, perhaps even 4.
Richard had a list in an older thread.
Do you trust 0.3mm nozzles to stay unblocked though? They may need periodic checking for peace of mind eh?
Cheers,
John
www.max-boost.co.uk
Old 11-04-2006, 08:22 PM
John, it would be for IC sparying and would be on a vavle so would only be used ofr some extra fun!
Blockage won't cause a major issue, and I'll be able to spot it easily. I managed to find the old thread you mention, and 4 is ok!
Old 14-04-2006, 08:14 AM
4x 0.3mm is perfectly OK. The 0.3mm jet has internal filter, but advisable to run a second 30um filter following the main 100um filter to reduce the workload of the jet filter.
