Old 29-05-2006, 08:31 AM
Rogercordia Rogercordia is offline
Default When do i inject the methanol mixture
alrighty ill start by saying abit of info for the cordia. A cordia turbo can boost to -
Intercooled 10 psi - 20 psi plus
Non intercooled - 10-12 psi.
When i drove my white un intercooled 1.8 litre cordia turbo, it would ping at 18 psi, when i installed the metho injection kit, i could boost it past 20 psi now without any pingoing or any othernasties. I cant belive how good it is, i can feel the torque straight away and it just accelerates so much more.
Currantly im injecting the metho injection at 12 psi, what is the best time to inject, should i inject at 10 psi and onwards, or should i inject at around 15 psi.
remember for a un intercooled cordia safe limit would be around 10-12 psi, but cos its metho injection i can boost its so much more like i said. So what boost pressure would be best for maximum performance.
my ignition is at 10 degree's.
Old 01-06-2006, 11:47 PM
what is your compression ratio?
Or
injection a few psi before the onset of pinging.
Old 11-06-2006, 12:33 PM
Im not sure exactly but currantly im getting the meth injected at around the 10 psi mark. i let it boost to 18 psi or maybe even more.
Old 11-06-2006, 08:25 PM
as long as you don't experiernce knock, you are in good shape. most of the time.
