Old 15-07-2006, 12:43 AM
boosted_gts boosted_gts is offline
Default need to know injector info....
Ok i am going to install a direct port injection system to my manifold but i need to know if a 1/4 hose size will fit on the aquamist injectors...reason being is i already have another brand pump and hoses that i would like to use for water injection but i would like to use the aquamist injectors for it. Does anyone know if it will fit? Also does anyone know a good place onlime to purchase the aquamist kit and parts? Thanks
Old 18-07-2006, 03:31 AM
can anyone please help?
Old 18-07-2006, 03:57 AM
simple simple is offline
Mate, I jast got some nozzles and they are 4mm. I belive there are also 6mm tails available. It's all listed here:
http://www.aquamist.co.uk/sl/plist/frm-4-USD.html
There is also list of distributers you can call.
This is all I can do for you. This forum is really informative but takes ages for a new person get helpfull answers as most piople here only visit this place few times a week.
Old 20-07-2006, 02:24 AM
turbojack turbojack is offline
Go to the Aquamist website then click supplier listing. Click USA or Non-USA. Look on the right side to see the resellers...I copied the links to each below to save you the time.
USA
NON-USA
http://www.aquamist.co.uk/sl/plist/frm-4.html
Contact the reseller directly and explain what you are wanting to do. They will be able to get you the parts you need.
I have not heard a bad thing about any of them so you should be OK picking one on your own.
Also, stick with the 4mm or 6mm line that is intended for the Aquamist jets, US or SAE do fit but it's a pain to get them on properly.
If you are using a surflow pump based kit you need to get 2 x 3.8 to 1/8 BSP adapters so you can switch to the Aquamist fittings.
Attached image should help.....I got it from another thread on this forum but can't remember the specific thread
