Old 27-07-2006, 06:35 PM
Maxxamillion Maxxamillion is offline
Default CT9A - 2006 Mitsubishi Lancer Evolution IX MR
I will be installing a 1s system soon but I have read about spraying into the turbo to spool faster and increase the amount of air the turbo can flow. I live in Arizona so it is very hot here and I was going to possibly spray before the turbo and before the throttle body with a water/methanol blend. I had a friend tell me that for some reason you can spray before the turbo on an Evo but I don't see why not. I just wanted to get some input from you guys. I will be installing the kit anyways I just need to decide if I will spray before the turbo also.
Old 27-07-2006, 07:31 PM
JohnA JohnA is offline
I'm a big fan of pre-turbo injection.
As long as you aim for the centre of the compressor it kicks ass.
You also need the injection before the throttle though, because no water will make it in liquid form through the compressor.
Cheers,
John
www.max-boost.co.uk
