Old 13-12-2006, 11:23 AM
Wolf_Tm250 Wolf_Tm250 is offline
Default Egt limited engine
Hello,
i am still a newbie of the wi... but i have the suspect it's an issue i could ask your advice for...
What would you do if you had an egt limited engine?
I mean, i still have boost (0.4 bar) to run with good turbo efficiency, but now i have skyrocket egt (950 C at valve exit = 1070 C at turbine inlet) at 2 bar and no det.
Any advancing of ignition timing ( to lower egt) gives me det.
Can I presume that:
- mine is end has det (cause it disappears when i retard ignition) ?
And that:
- i have my ppp way later than 14 deg atdc (cause my egt are so high) ?
So, afaik, my goal should be to fight end gas det... correct? So that i could advance a bit the timing to lower egt without having det.
For this purpose, what are your advices about wi?
Pure water, 50%meth?
Any other consideration or tuning advice?
Thank you...
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Toyota Celica Gt-Four ST205 Snowy White[2.34kg/hp]
Old 13-12-2006, 12:19 PM
Hic Hic is offline
wolf
contact me, you have my mail, I will help you
