Old 20-04-2007, 09:14 AM
Wolf_Tm250 Wolf_Tm250 is offline
Default HFS-5: how to map it
I have an HFS-5 system, w/o FIA2, but PWM controlled by my Motec ecu, and 2 x 0.5mm jets after IC outlet...
question...
given that I have to look for a water's quantity of 10/15% fuel, what kind of values I'm looking for, on my PWM map, accordingly to my fuel injection map ?
I mean... what kind of relationship is there between PWM map values, and quantity of water flowing through my jets ?
Thank you.
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Toyota Celica Gt-Four ST205 Snowy White[2.34kg/hp]
Old 29-05-2007, 12:39 AM
Once you have picked the jet/jets and put the matching restrictor before the HVS, the PWM % should be a percentage of the jet's maximum flow.
Old 29-05-2007, 07:36 AM
Oh..... this is VERY interesting....
Thank you Richard!
Old 18-06-2007, 11:41 PM
So...
the PWM values, I'm going to write in my PWM map, are, in fact, a percentage ??
Old 22-06-2007, 12:14 PM
ride5000 ride5000 is offline
you can always remove the jets from the intake, direct them into a container, and actually test the effective throughput of different valve duties. this is exactly what i plan to do with my system.
just keep in mind they will be slightly reduced when the jets must discharge into a pressurized intake pipe instead of ambient air--ie true flow rate will be lower than tested when running high boost. luckily the high rail pressure of the hfs5 pump will minimize this effect.
ken
Old 29-07-2007, 10:17 AM
ken
Good idea !!!
Old 29-07-2007, 10:54 AM
How would you map the PWM signal ?
According to which 2D values ?
Boost & air temp ?
Inj duty cycle and air temp ?
TIA.
Old 29-07-2007, 10:34 PM
i am planning on using MAP and RPM.
pressure sensors are "faster" than temperature sensors... i think you'd observe a pretty tight correlation between MAP and MAT (manifold absolute pressure and temperaure respectively).
