Old 02-03-2009, 07:36 PM
flyingbrick242 flyingbrick242 is offline
Default PN# for flow restrictors/connecters.
Just purchased a used HFS-5 system with DDS3 V10, only used one month.
I'm one lucky guy!
I went over the kit and found that its missing some unique parts that I can't find part numbers for.
Can someone help me obtain these?
1-In line restrictors for HSV, the parts list claims it came with three.
2-The HSV retaining clip.
3-The connector and terminals for the water level sensor. [two pole]
I'm still in the process of learning this systems ability and features.
Question: Is the injecter pulse signal all that is needed for the system to work correctly. Not spraying until boosted?
Installing in OBDII fuel injected turbo engine.
Thank You.
Old 02-03-2009, 11:52 PM
You are one lucky people for sure. Dud he gave the reason why he was selling the kit?
If you like to download HFS-5 v10 user manual, you can use the following link:
Call Jeff at Howerton Engineering, he should be able to help you out, he should have Aquamist spares.
Jeff Howerton
707.685.6279
Answer to your question: you need injector pulse signal signal for sure. The system can be set to trigger by boost or IDC%. Read the user manual, it is all in there.
Old 03-03-2009, 12:04 AM
He sold the kit because he has a child on the way......wife made him :twisted:
I have been in contact with Jeff......Very helpful and we got it handled!!
Thanks for the reply!.
