Old 19-06-2009, 11:59 AM
swfblade swfblade is offline
Default Audi TT nozzle size/flow rate question
Hi all,
I've got an Audi TT 225, which is stock, so about 221bhp/207ftlb at the fly. I brought a WI kit a few years back for an old VW Corrado G60. Its a dual stage kit, and has 1 x 1gph nozzle and 1 x 2gph nozzle. I am getting the car remapped soon (claims up to 45bhp/80ftlb increase, so around 266bhp/287ftlb).
So, is there a set calculation or amount that should be flowed thru for the power, or can anyone let me know if this flow rate is going to be enough?
Many thanks.
2002 Audi TT 225 Coup?
1971 VW 1302s Karmann Cabrio
Old 22-01-2010, 12:38 PM
Been a while... no response
Had the car Remapped some time ago. MAF readings show peak torque of 276 ft.lb @ 3200, dropping slowly after that and staying above 200ft/lb all the way to 6500.
Can anyone advise me on my WI kit? Would it be worth it? If not, I'll sell it on, not sure how much its worth tho...
Old 22-01-2010, 01:11 PM
Howerton Engineering
Can you tell me about the pump(psi) for the system so we can see what the nozzles will actually flow? What brand/model is the system?
Also, can you give us some specifics on application, how much you may have raised boost, what octane fuel you run, fuel injector size, etc.?
