Old 17-08-2009, 05:58 AM
Crazy AWD Crazy AWD is offline
Default HFS-6 DOA?
Checked the power connection. I have 12V on the red wire and a good ground on the black/white wires. Wires appear as such:
I get 12V on both sides of the fuse.
Ground wires to chasses shows little resistance.
However, I get no lights on the HFS-6 control board nor any lights on any of the RJ45 connectors. I also don't hear any relays click when the car is in position II and the red wire is powered.
I'm still looking at the circuit board for a bad solder joint but haven?t been able to find one.
I'm thinking my board is defective.
Old 17-08-2009, 12:09 PM
Just to nbe obvious, if the gauge on/off button depressed?
The system will not switch on until you applied a 12V to the red wire of the yellow harness. Check the connection and let me know.
If the green led is not lit on the yellow RJ connetor, It confirmd that the red red is not seeing a 12V.
Old 17-08-2009, 03:24 PM
Bingo! That's what I overlooked. I will try that and report back. (wanted to test the system first before getting into the ECU box.
Old 17-08-2009, 03:54 PM
Put a test +12V to the red wire in the yellow harness and the test worked perfectly! Thank you for the rapid support Richard!!!
Old 18-08-2009, 12:39 AM
Thanks for the update. much appreciated.
