Old 16-01-2010, 12:17 AM
vRSy vRSy is offline
Default W/M Inj on Vag 2.0 TFSI
hi there
I have a Mk2 Octavia vRS 2.0 TFSI, currently maxed out performance wise on the std internals and turbo @ about 270-280Hp, with stage 2+ remap, full exhaust system, intake, fuel pump and intercooler.
Im now looking into w/m injection but have found very little from info from the UK reference the installation and perfomance possibilities available.
So...im going to bombard you guys with questions
1-There are lots of kits available from the likes of snow perfomance, devils own, AEM, aquamist etc etc what would be the reccomendation to install or benefits of one kit over another?
2-What is the best method of controling the meth injection, boost or MAF activated.
3- what is the average amount of time to install a full kit start to finish, so i can get an idea of the labour charge id have to pay.
4-I have a custom map on my car at the moment, if i was to run water methanol on top of it without tweaking the map, would i still see gains in HP and torque.
5-My tuner has already said he'd be more than willing to tweak my map for me, to utilise the w/m inj. what sort of gains are you looking at when the map is tuned for it
6-storage of meth- i know you can utilise the std washer fluid container, but i use my windscreen wash alot so wouldnt want to waste the mixture. If i had a seperate container put in the boot, is it possible to have a quick release style container that can be released to remove the container from the boot when the w/m inj is turned off(should i need my boot)
7- does anybody have graphs to show before and after gains on their cars, so i can get an idea of if it will be worth the outlay.
Also is there anything i might not have considered
Cheers guys
Old 16-01-2010, 02:49 AM
Howerton Engineering
You do have a lot of questions. We will try to answer them with as much detail as possible.
1. Many of the kits listed, except Aquamist, are what is called Progressive Pump Speed Systems(PPS). These kits change the speed of a pump to change the amount of injection. The Aquamist systems use a constant pressure pump and a control vis a valve similar in junction to a fuel injector. The Aquamist system acts similarly to a modern fuel injection system.
The merits of PPS systems are that they are inexpensive and have few components. The drawbacks are they don't track the engine load very well and have a very poor dynamic range. This can lead to erratic AFR's over differing load ranges and difficulty in tuning for proper driveabilty and power across a broad range. There have been entire papers written on this, we can refer you to more materials if you like.
The merits of the Pulse Width Modulated Valve system (PWM-V) that Aquamist uses are precise injection across all load ranges of the engine and repeatability across the same load changes. This leads to precise AFR control maximizing efficiency and power across the whole load/rev range. This is due to the wide dynamic range of the systems.
Any system can achieve the same max power output on the dyno in a narrow rev range if jetted right, it's all other aspects of the rev range and driveability where the differences can be significant.
2. MAF or Boost are the general means of injecting for the PPS systems, a few track IDC. Aquamist uses Injector Duty Cycle(IDC) as it's primary reference for controlling the injection amount. IDC is the most effective measurement of load on an engine thus generally providing the most accurate means of injection. Some of the systems including Aquamist(some kits) allow a mix of IDC and Boost to control the injected amount.
3. Depending on the type of system and car the install time can vary greatly. The time really changes with where the jet is installed(how much of the engine/car comes apart) and how clean you make the install. I would guess time can vary anywhere from 3-8 hours. You should contact a shop that has performed installs before and ask what they have experienced in the past.
4. This really depends on the engine configuration and mapping. If you are octane limited and have heat soak issues you could see a benefit without tuning. Some cars have lost power by bolting on a kit and not tuning for it. We would need more specific info about your application to dive deeper into this.
5. Again, see above. This depends on how octane limited you are at the moment. If you have the ability to increase boost and timing with more octane then increases in TQ and power can be realized.
6. We have done this in the past with some systems we have built. These utilized a quick release tank/pump mount, a quick disconnect for the power/control wires and a high pressure quick disconnect for the pressure line after the pump. It can be done, this just depends if the benefits outweigh the costs in your application.
7. Again, see 4. This really depends on the amount of boost and timing you can add to your configuration. Some of the stock 2.0L WRX engines in the States can see quite significant gains, while other makes of cars with more limitations won't realize as much.
Let me know if this helps and we can elaborate more in more specific areas.
