Old 13-03-2010, 05:46 AM
ziad ziad is offline
Default install on an Evo 8MR
been slowly doing this install over the last week. And to see it work properly the first time go... I am very happy. Thanks to Richard for his hard work with diagrams and instructions, which resulted in everything working like they should.
Anyway I will put up some install pictures for now, text and my comments later
Pump in the wheel well (hope it does not effect it seeing its upside down)
the 6QRT tank, mounted on the right side. I am using a bracket to hold it in place. the washer bottle is a pain to get to with the carpet installed.
I routed the supply line to the FAV underneath the car, there are a few places that were tricky and I might re do them when i get the car onto a hoist. but basically running next to the fuel and brakes lines
the picture of the FAV, it can also be seen from the front of the car. anyway there is a big support beam under the airbox, on one side the boost solenoids are.. this is on the underside of the beam. I taped some holes and bolted the FAV there
this is the upper IC pipe jet, surprising the IC pipe is quite thick, and will hold the npt fitting. i used Loctite Red to ensure that its sealed properly.
this is the jet right after the IC.
Old 15-03-2010, 12:56 AM
taiman taiman is offline
Default Re: install on an Evo 8MR
good stuff ziad! lets see some figures now!
Old 17-08-2010, 06:34 AM
cammy cammy is offline
nice install ziad
really looking forward to seeing your results.
