Old 01-07-2010, 06:45 AM
andernalin_junk andernalin_junk is offline
Default problem with amount of w/m and system setup
I have a problem
i tried to adjust the system according to the manuel,
jet size 0.6
I can't get the system to work on 5-6 bars on the controller
the maximum i could was 4 bars only when boostcontroler is off
when boost controller is on i cant get above 2 bars on the controller (sc is all the way down)
any souletions anybody ?
Old 01-07-2010, 08:10 AM
Default Re: problem with amount of w/m and system setup
can you tell me which system do you have?
Old 01-07-2010, 08:24 AM
Sorry , HFS-5
only duty cycel switching , no map/map/boost
Old 05-07-2010, 05:50 AM
anyone ? i'm kind of lost hare :cry:
Old 05-07-2010, 08:27 AM
The problem is probably due to the low flow required. The flow sensor is configured for multiple jets. Please let me know the serial number of the flow sensor.
In most cases, there should be enough adjustment on the "SC" trimmer to run a small jet. Please check the partial clog on the disc filters on each end of the flow sensor. Try back flushing it.
Do a quick test: blow throw the sensor, it should display full 8 bars.
Old 05-07-2010, 08:45 AM
part no . 806428
s/n 3117
I ran the system on TST mode yesterday, it shows full 8 bars
