Old 18-09-2010, 05:58 AM
WhiteKnight WhiteKnight is offline
Question Gauge Power problems
Hello Guys,
I have HFS-3 system installed on my Porsche 997tt.
The problem is;
The system is working and i have 5-6 bars of flow, but while going WOT, sometimes gauge loses power and it comes back very quickly in about half seconds.
It goes off and on again 2-3times during a 60 to 270km run.
What can be the cause?
My findings;
- Take of the plug of WATER LEVER sensor.
- Seperate the BLACK/WHITE grounds from each other.
- Check the resistance of the grounds.
- Check WL AND WH. (I have already set them to the limits. WL 7 o'clock, WH 5 o'clock, so i dont think that im reaching the failsafe)
Anymore ideas?
Thanks,
Emre
Old 18-09-2010, 08:26 AM
Default Re: Gauge Power problems
The first thing I think off is the anti-backout tab of the RJ connector. Try bending it out manually until it is arount 45 degress from the horzontal. Do it for both ends. If the gauge is insde a tubular pod holder, it tends to press on the tab.
I would try this. I don't think it is a fault trigger from the electronics.
Old 23-09-2010, 11:50 PM
Dear Richard,
I tried bending the anti-backout tab of the gauge, but it didnt help. However i havent tried the controller side.
Here is a quick video of the gauge during full throttle run.
http://rapidshare.com/files/42087265...00924-0132.3GP
By the way, water level sensor is disconnected in this run to make sure that this fault is not related with it.
I'm really pissed off, i hope you can help
Old 24-09-2010, 10:19 AM
Easier link for the video;
http://vimeo.com/15245055
Old 24-09-2010, 02:02 PM
Just saw the video, terrible.
I will send you a new cable, pm me your address.
