Old 30-09-2010, 04:59 PM
stevebez stevebez is offline
Default Is checkvalve necesary?
I have HFS6 with jets installed in off boost vacuum area. Is the HFS6 system "water tight" when off, or is a vacuum check valve needed?
Rgds Steve
Old 02-10-2010, 12:07 PM
Default Re: Is checkvalve necesary?
Hello Steve,
A check valve will help if your jets are wide apart, stopping the siphoning-off effect due inbalance of vacuum betwem the two injectionpoints. The HFS-6 is water tight at the off position. the fluid is shut off by an inline solenoid valve.
