Old 26-11-2010, 07:37 AM
Wolf_Tm250 Wolf_Tm250 is offline
Default WI error on dyno but not on road!
my system is HFS-5 dds3 v8, 2 x 0.5mm.
Any idea why I get WI error (with the wanted boost limiting effect) during dyno pulls, but not on road pulls??
I have plenty of water so it's not a water level issue...
Thank you.
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Toyota Celica Gt-Four ST205 Snowy White[2.34kg/hp]
Old 30-11-2010, 01:34 AM
Howerton Engineering
Default Re: WI error on dyno but not on road!
How do you have the gauge spanned (SC setting)? Does it come on at about 2 bars and finish at 6-7 bars at redline?
When does the system failsafe happen, at the start of the pull or the end and what is the gauge reading when it does?
Old 30-11-2010, 02:09 AM
The failsafe happened many times at midrange, around 5000 rpm, when WI is injecting huge quantity...
Yes, bars are still from 2 to 6...
Is there a way to know if failsafe happens for a WL or a WH problem?
Old 30-11-2010, 03:50 AM
The WL covers the left 4 bars and the WH the right 4. You would have to see what the unit is displaying when the failsafe trips.
Old 30-11-2010, 04:49 PM
Ok thanks.
Moreover during dyno pulls the WI failsafe comes on and off continuously and intermittently whenthe WI flow is at his max... so maybe is just a too narrow window problem...
Old 30-11-2010, 05:02 PM
Could be the WH needs to be adjusted a little.
Sounds like you don't drive your car hard enough on the road.
