Old 10-04-2011, 01:00 AM
flyers7732 flyers7732 is offline
Default Gauge problem?
I've installed everything per the directions and my gauge led's stay lit all the time all the bars are lit, ibe tried to change them with the dials and no luck am I doing something wrong? The jets do spray car has been tuned already but I can't get the bars to work thanks...
Old 10-04-2011, 01:04 AM
Default Re: Gauge problem?
please check the gauge cable. Col0ur orders should be mirrored
Aquamist
Old 10-04-2011, 03:10 AM
Yes they are mirrored
Old 10-04-2011, 09:16 AM
Good.
Did you hook up the dimmer circuit? Purple wire on the 4-pole power-in connector.
Found the drawing:
Old 10-04-2011, 12:00 PM
another possibility could be tiny strands of wire is shorting across the tip of the RJ45. You need a powerful magnifying glass to examining it properly. This can happen on an flexibily cable.
Old 10-04-2011, 05:47 PM
It is hooked up to a headlight switch and I did look at te ends and it seems that there is a strand of wire from the grey going to the white
Old 10-04-2011, 06:48 PM
I found a cable and now I have a different problem haha my luck, gauge works somewhat now, when I turn the sc the gauge flickers far left it goes fully lit far right ir turns off and the other two dials dont show bars moving? Should they move so I know what it's set at or just by the clicks, thanks for the help
Old 10-04-2011, 07:22 PM
Whatever you do , do not use a standard off the shelf RJ cable as they are non-mirrored and twisted. You can damage the gauge and have unexpected results.
Old 10-04-2011, 07:23 PM
How long ago have you had the system? I like to check if we have some gauge cable problem during that period. Pml me your address, I will send to a tested cable (by me) just in case.
Old 10-04-2011, 08:07 PM
I've had the system since October but it has not Bren installed until now, I did use a cable and that does affect it like you said so I'll unplug that now, my pm dosnt work for some reason so me address i
Please let me know once you copy it down so I can erase it from here thanks !
