which jet after upgrading from 1s to 2d
hi !
i am upgrading my 1s-system to a 2d-system in my 1.4l 4-cylinder turbocharged car (cr 9:1 and 1.2-1.3bar boost pressure with bigger turbocharger). when using the 1s-system i ran a 0,8mm jet right before the throttle body which starts to inject at about 0.7bar. which jet size shall i use with the 2d-system ? thanks. |
depends on what water percentage do you want to run?
