Old 20-07-2011, 05:35 PM
sebdut sebdut is offline
Default Boost trigger
What is the fonction of the boost trigger wire on an Audi s4 wiring diagram?
Old 21-07-2011, 03:35 AM
Howerton Engineering
Default Re: Boost trigger
If you hook the blue wire up as shown, you can change a jumper on the control board, on the left side, from IDC to MPS. This allows you to trigger the system at a specific boost point instead of an IDC point. For example, you can set the system to start spraying at 5psi, then inject on IDC after. The trip/trigger pot is now used to set the boost point at which you want to inject.
Old 04-09-2011, 09:59 AM
EvoX612 EvoX612 is offline
Please explain where to adjust, is it the THRES Trimmer?
If yes what is the trigger point in 12 o clock position? Bar or psi value ?
Old 11-09-2011, 04:33 PM
When the MPS is linked, the THRES pot is used to set the boost point at which the system is activated.
The pot works on 0-5V signal and the range of the pot is 12% to 72%, same as the IDC. I don't remember if some of the vacuum range is clipped or not. If not, take the range of your MAP sensor, for example 3 bar, and calculate it over the range of the pot. So if 12 o'clock on the pot is 44%, then it would represent 4.7 psi of boost.
Old 24-02-2012, 01:41 PM
Thanks it works! Perfect
Old 28-06-2012, 11:31 PM
ek9max ek9max is offline
What is it's a 2.5 bar sensor? What position would I want if I want to start spraying at 4psi?
My tuner recommended me an AEM kit and start spraying at 4psi and full at 16psi.
Can you do that on an aquamist?
