Old 18-09-2011, 12:15 AM
ysfg35 ysfg35 is offline
Default have qusetion please
am running my aquamist methanol injection and am very vary happy , great prodect , clean and you can feel the quality ..
anyway , i have a simple qustion :
*the system settings are working fine with my setup , in the future am going to run race fuel c16 , and i should not run methanol injection ,
in the same time i do not want to lose methanol Advantage of cooling the iats , so i decide to run less amount of methanol to cool the iats ..
as i know there are 2 way to run less methanol :
- use restrictor
- adjust the gain little down
which one is better ??? any other idea ??
btw am useing 2 jets , and i can not run just one ..
thanks
Old 18-09-2011, 04:20 PM
Default Re: have qusetion please
Either one will work.
Gain will only affect the spray from threshold point onwards. Restrictior will reduce the entire curve.
I think lower the gain will be better as having colder air lower down helps spool up. As RPM rises, the system will not spray as much.
Old 19-09-2011, 12:28 AM
thanks alot man .. i think restrictior will be better , cuz i do not want to adjust the settings again and again ..
Old 19-09-2011, 09:09 AM
I suggest putting in the 0.7mm restrictor.
Old 19-09-2011, 03:18 PM
you are right .. will do that and see ..
thanks richard
