Old 18-11-2011, 03:54 PM
infinkc infinkc is offline
Default injector duty cycle question how it controls the aquamist
Had a question on how the cars IDC controls the aquamist system.
My car has a max IDC of 80% on my tune. Does this mean i should lower the setting in the controller at account for the difference? does aquamist assume 100% duty cycle on the injectors?
Or is it relative to think that, for the car since 80% is the max, the controller will know that is 100% in the application its being used for?
Thanks!
Old 18-11-2011, 08:13 PM
Default Re: injector duty cycle question how it controls the aquamist
The default setting on the HFS3 mirrors the incoming IDC at 1:1 ratio. If you want the HFS-3 to inject 100% DC with a 80% incoming IDC signal, just use the gain trimmer.
One easy way to achieve this is by observe the red 95% DC led, just advance the gain trimmer until this led just come on. There is no progression in flow beyong 95% DC
Old 21-11-2011, 03:44 PM
i have an hfs5, is there a gain trimmer on that model?
Old 21-11-2011, 03:46 PM
On the HFS-5. there are no gain treimmer. It is fixed to 1:1 ratio. Th eonly way to alter the water/ful ratio is by sizing the water jet against your total fuel flow.
