Old 29-01-2012, 07:57 PM
TJ TJ is offline
Question Stainless Tubing
Thinking to replace the nylon tubing with stainless. What is the ID of the 6 mm and 4 mm tuning that comes with the Aqumist kit?
TJ
Old 30-01-2012, 08:29 AM
Default Re: Stainless Tubing
6mm ........ 4mm id
4mm ........ 2.5mm id
Old 31-01-2012, 10:06 PM
keithmac keithmac is offline
What fittings are you going to use, I bought some stainless tubing but decided against fitting it as the quick disconnect fittings wouldn`t "bite" hard enough and I could pull them off the tubing relatively easily.
