Old 24-02-2012, 01:46 PM
EvoX612 EvoX612 is offline
Default When I switch off my car, the pump goes on even the switch is off ion the gauge.
... Switch is off on my gauge !
Very annoying as it will drain my battery.
Please help
Thx
Old 24-02-2012, 07:31 PM
Default Re: When I switch off my car, the pump goes on even the switch is off ion the gauge.
You must only connect the red wire of the grey harness to a switched +12V source: only active at the "pre-crank" key position. Read page 11 of the user manual again.
Old 25-02-2012, 06:27 AM
I have connected the wire to the Injector + as per the installation picture.
shall I change it a switched +12V source?
Old 25-02-2012, 10:27 AM
This weird...
The entire HFS-3's power in control is activated by the red wire of the grey connector. As far as I know, the fuel injector (+) should not be "live" when you switch off the car.
Is your car a factory standard.
Just to certain, can you check the injector(+) for me to ensure there is no 12V present there when you switch the engine off.
Old 25-02-2012, 09:49 PM
I put it as you said on the 12 V source and it works fine.
Thx
Old 25-02-2012, 09:55 PM
Has it solved the "car switch off" problem?
Old 27-02-2012, 07:32 AM
Yes it solve the problem. Thanks
