Old 25-02-2012, 09:53 PM
EvoX612 EvoX612 is offline
Default Hks evc boost controller
How to make the boos controller lower the boost automatically when the tank is empty?
Old 25-02-2012, 10:02 PM
Default Re: Hks evc boost controller
The HFS-3 does not switch to low boost when the tank is empty but it will reduce boost if the water flow is outside the failsafe window.
This is because the tank doesn't become empty instantly. Instead, it goes into an intermittent state when it is approaching empty. If this is tidied into the boost drop, the boost pressure will react badly. So under these conditions, the water level led on the gauge will flash, warning the user the tank is approaching low level.
If the tank level is low before the the ignition key is next recycled, the HFS-3 will not switch on after 5-10 second. The yellow dash gauge led will state on.
Old 27-02-2012, 07:37 AM
I believe I should use a MAC to make lower the boost.
I have a Motec ecu. I use only one map.
Up to one 1 bar is without methanol injection.
After that is 1.6 bar with it.
If the tank goes empty how to make the boost come to 1 bar automatically to avoid breaking the engine.
Thx
Old 28-02-2012, 09:55 AM
The HFS-3 monitors the flow all the time. Use the onboard failsafe (grey connector).
Page 17, 18 of the user manual. (You) can make use of ther MAC valve. Read the wiring diagram for the EVOX on this forum.
This way to save your engine is much better than the water tank level.
Old 28-02-2012, 05:02 PM
Page 17, 18 of the user manual. YPOiu can make use of ther MAC valve. Read the wiring diagram for the EVOX on this forum.
What does YPOi mean and my car is a evo IX noe evo X with Motec m800 ecu
Old 29-02-2012, 10:47 AM
It is a typo (you). The evo 9 is easier with a mac valve. Can the motec control boost?
